vibration durring coasting
hipo50mustang
ok, a few weeks ago i swaped out my gears to 3.73. now I have a vibration only durring coast. when I accelerate, everything is fine. I just ripped out the rear end today and tomorrow I am taking the diff out to check the shims and spacing.
what, exactly, should I check so I wont have to do this a third time?? :wall:
Thanks,
Mac
H
hipo50mustang
the u-joints and driveshaft are fine. i checked those before ripping out the whole rear end again.
anything else?
H
hipo50mustang
new ring and pinion,
finally got the diff back in, I think it was the pinnion depth was too shallow, not enough shims. I remeasured the orriginal pinnion depth again and it was off alot. then i readjusted the back lash to within spec,
now I just have to get the rear end back under the stang.
will let ya'll know when she is back on all 4's again. should be tonight if the weather hold out.
wayne94mustang
my car did this and it ended up being the u-joints....they dont have to have play to be bad
mine were tight as new but some joints have a plastic disc in the end of the cap and mine were tore up and hunks were in the brearings
H
hipo50mustang
well, it is all put back together and the vibration is gone, but now there is a whine. i think i put a little bit too much torque on the preload on the pinion, but I can fix that.
I am going to check the ujoints while I am at it also.
Thanks for the input.
wayne94mustang
how much preload did you set it at?
i like 25-30 ftlbs of rolling risistance (i cant spell) with new bearings....this is what my papers call for anyway and i have done 20 or so 8.8 rears
H
hipo50mustang
do you mean in/lb not ft/lb? because it should be somewhere between 8 in/lb and 24 in/lb depending on what source you read it from.
I have no idea because none of my torque wrenches go down that low to check, so I used my well calibrated breaker bar and stopped torquing when it felt right, which i know now is definately NOT RIGHT!! :wall: :wall:
taking it to a place with a lift so I wont have to take the whole damn rear end out again.
H
hipo50mustang
well, i am 98% that it is the excess preload that is causing the whining. but i dont have the time to take it all apart again. woulld be alot easier if I had access to a lift. so I am taking it to a shop next week. :crying: i know the pinion depth and backlash are correct now, just the damn preload.
vettekiller3
its probably the pinion crush sleeve. Get a new one and crush it(takes about 400ft/lbs. but ifyou take it to a shop theyll do this for you
John
H
hipo50mustang
shop fixed it. replaced ALL the bearing while they were at it. no whine or vibration now and she runs strong. thanks.
