Vibrations at 80+
cobrajeff96
Germany
The engine/trans will face down slightly. And of course the opposite with the rear pinion. The less of an angle you have the better, but you don't want zero/zero. Anything between 1 to 2 degrees is fine. I have 1.7 down trans and 1.7 up pinion and it's butter smooth. Key thing is to treat the measurement process as scientific, accounting for consistency and repeatability in your 'tests'. Otherwise, you're fooling yourself.
Also a key thing to remember is that if a car sits for more than just a few months, the weight of the car will shove out all the wheel bearing grease and maybe other things too like balljoints. As pretty much everything on a car is connected and load bearing, it wouldn't be crazy to think that for 8 years sitting still the whole entire suspension needs a re-work.
If you don't feel any vibes in either the seat, the steering wheel, or both, then maybe this can be overlooked. But certainly the rear axle bearings (I assume this is an SRA) and possibly the diff bearings ought to be inspected as well. Pinion bearing for that matter too, checking for runout I would assume. Usually with worn or out of spec rear gears you will definitely notice some awful sounds. Do the obvious and easy checks too like checking trans fluid level. I mean.....8 years. Damn. It wouldn't be crazy to think that all fluids should be flushed if not already.
OldZeuski
OldZeuski
I appreciate the input. I guess I need to mention everything that's been done on this thread. I've been asking a lot of questions and mentioning bits and pieces on multiple threads.
Specific to what you've mentioned. I've replaced the entire rear suspension: control arms, springs, shocks, axles, bearings and all differential bearings. I've also replaced the driveshaft with an aluminum one and new U joints (balanced at a shop). And I have new wheels and tires balanced as well. The trans was rebuilt a few weeks ago with everything but the gears and shafts. My pinion angle is now within 1* of the trans after I installed and adjusted new lower control arms. But still, the vibration exists and gets terrible around 100 mph. Before my adjustable LCA's I was at 3.5* difference between the trans and pinion. I thought surely that was my problem but it did not improve anything.
I don't feel anything in the steering wheel and only marginally in the seat. But this vibration is intense the higher I go above 80.
I have an arduino and an accelerometer that I'm going to try and rig up to either shifter or the axle housing and see if I can data log the exact frequency of the vibration. I know there are frequencies that correlate with different pieces of the drive train. I'm still convinced this is an alignment/angle issue because literally everything is new and tight.
OldZeuski
OldZeuski
Also, It seems like the trans is angle UP and not down. To be honest I can't quite visualize how the trans would be angled down relative to horizontal, and the pinion UP, if the pinion is physically lower than the trans. I've never seen a diagram where this is true. Mine is more along the lines of "Right".
driveshaft-does-not-need-to-be-perfectly-aligned-with-the-transmission-output-and-the-final-dr...jpg
cobrajeff96
Germany
Hard to imagine any SN95 Mustang's engine slanting upward toward the rear of the car. I've never seen or heard anything like that.
Bear in mind that the closer you get them to equal & opposite angles the less chance the driveshaft has of inducing vibration into the drivetrain. Within one degree might sound good, but it's best for the two u-joint angles to cancel eachother out.
And I didn't think you could adjust pinion angle by the LCAs, only the UCAs.
OldZeuski
OldZeuski
So your driveshaft at the pinion is opposite to what is shown in the photo i posted? My pinion and drive shaft make the angle pictured, same as my trans.
I have been able to adjust with the lower control arms just fine. It only took a few turns of the nut to get it to move 2-3*. It would have worked just fine with uppers as well but I kept the uppers stock to allow for some flex and avoid binding the rear suspension.
OldZeuski
OldZeuski
I've been adjusting the trans, driveshaft, and pinion angles only in relation to each other. I haven't actually measured my trans angle in relation to the frame of the car, It just visually appears to be angled up. I will actually measure it next time I'm down there.
cobrajeff96
Germany
Are you taking measurements with the suspension fully loaded? It's the only way to do it on an SRA car.
Keep in mind that when you alter the LCA lengths, you are changing suspension geometries such as instant center. And you might be affecting wheel-to-fender clearance fore-to-aft. Maybe it works fine, I don't really know as I run IRS myself so it's been a while.
In a bellhousing car, it's common for the front end drivetrain to be angled down towards the rear of the car for the obvious reason that it has to generously clear the tunnel. I have never seen a Mustang that showed the opposite, and the pinion has always been angled upward to compensate the driveline angle chiefly for that very reason.
OldZeuski
OldZeuski
Update
Had the wheels road force balanced. One is at 79 lbs road force variation, another is at 30. They could not get them any better. Wheels all balanced perfectly at the tire shop, so this problem was only detectable on a road force balancer. The other two wheels were better and were brought down to <5 lbs
