More specific applications then:
Vortech S trim, straight onto a NPI 4.6 with BBK throttle body with C&L plenum, Shorties, Bassani X and Flowmasters. In other words a very typical NPI GT, no PI bits yet, no power pipe yet, just S/C on a fairly stock NPI setup. And yes, the car is a stick. 267RWHP/310RWTQ. Why so low? The NPI stuff really does breath that bad, it's due to the rapid dropoff in torque due to the NPI intake and cams.
http://www.modularpowerhouse.com/forums/showthread.php?t=41349
Anybody that is a member on that site can log in, go to his profile and see the dyno chart in his pics. Or it takes no time to join the site, I'm posting both cars because both cars were tuned by Tim on his dyno.
Comparing that with N/A cars that put out in the same region, in this case a PI 4.6 car with 267RWHP/303RWTQ, a pretty basic bolton car with accufab TB/Plenum, JLT intake, longtubes and exhaust and UDPs. it isn't hard to see the difference in the torque curve
http://www.modularpowerhouse.com/forums/showthread.php?t=48067
Are there N/A guys and boosted NPI cars with more? Sure. You could crank up the boost or use a more aggressive tune on the NPI stuff and get in the 300s, later add more to it. Many NPI cars put out 320s or so once you add a power pipe and other odd and end boltons. There are N/A guys putting out the same. But sticking to my original point that a n/a engine will be stronger overall than a centrifugally supercharged engine with the same peak power output, it's pretty easy to see that with the power curves. If anything the fact that it's a centrifugally supercharged NPI engine biases this comparison MORE toward the boosted NPI engine when comparing torque curves because of the fact that the engine makes peak power at the point that the torque has fallen off, means that for the same given power level it is even stronger in it's peak torque region than the power numbers would indicate (with these engines it's around 4000rpm), or would otherwise be had the torque curve been shifted more toward peak power output. Yet it STILL has a narrower torque curve than a head/cammed n/a engine with the same power output. I really don't see why this is so hard to grasp, the characteristics of centrifugal superchargers have been well known for a very long time, and every major automobile magazine has posted up enough data on boost curves, power curves, torque curves, timing curves of engines that run said superchargers, essentially every possible number you'd want to slap onto a piece of paper and verify.
If you want to make further power with a boosted NPI car, you're going to do a PI intake, if you go the RTV "cost effective" route it's $200, or add $500 if you want a kit with adaptor plates etc., after that you're going to want to go with new cams, which if you do blower cams it's gonna be $600 plus another $200+ for springs, or go with stock PI cams, spend whatever you can get a used set for, then you're going to be either spending time to install those, or paying money to have them installed and perhaps degreed should you choose to do so. So basically, you're buying a blower, then on top of that you're doing the exact same modifications that you would have made had you gone N/A and decided to grow later, and you're doing it just because you're trying to extract similar output to what a blown STOCK PI engine will put out.
Go the N/A route and you're already in the 300rwhp region, and with the head flow as well as the camshafts, getting big power out of that will be a cakewalk compared to trying to squeeze it out of an NPI engine. A nitrous kit is the el cheapo way or if you went with a blower later you'd get bigger power gains with less stress on the motor because you're running less boost with the same airflow, meaning less friction and less heat, thus less stress on our rather fragile pistons and rods. It isn't like somebody has to go to the extremes of ridiculous cams and head porting to get close to 300rwhp n/a, lots of guys are getting 280s and 290s out of setups that have blower cams and mild heads. There are people in the 290s with stock PI cylinder heads and a good set of cams, with a wider torque curve than the car gives you stock.
I wasn't in any way saying the N/A route was always the better option, but in this particular case, I definately feel that it is because you're spending roughly the same amount of money for around the same power output, while it'll be a little cheaper to get a few extra HP with the blower via PI intake, power pipe, etc., in the big picture an engine with ported heads and camshafts has a ridiculous amount more ultimate power potential than an NPI setup would have, then add the benefit of having a newer engine. If we were talking about tacking on a Kenne Bell instead of a Vortech it'd be a LOT different, a no brainer because a Kenne Bell adds boost right in the meat of the powerband where an NPI car can surely use it most. The boost curve of a centrifugal supercharger, opposed to positive displacement superchargers or turbos, is very narrow in ANY application, and the NPI setup just fights it that much worse.
