vortech t trim on a stock 5.0
itsblue95
Louisville Kentucky
Ive got a buddy that has a vortech t trim for a fox for sale. I was thinking about tring to buy it from him. Does anyone have a t trim on a stock 5.0? if so how does it run? how much hp/tq does it put down? Would it be worth $2500?
modo
Philadelphia, PA
yes its worth 2500, it would make a tad more power then a S or Si trim and has the potential to make a lot on a larger motor. i made 632 with one on pump gas a long time ago without spinning it hard on a 331
There are going to be some differences between the brackets for a Fox and for a SN95. You might want to check into those before you spend that much money on something that you wouldn't even be able to use yet.
vibrantred5.0
isn't a supercharger bad on a stock motor? like will a stock motor handle the power? I dunno......always wondered tho.
modo
Philadelphia, PA
not bad as long as there is enough ring seal
Good tuning can do wonders as long as your motor isn't falling apart.
vibrantred5.0
( I'm still learning everything bout cars so) whats a ring seal?
sorry blue95 i kinda hijacked your thread....
5.0kid
haha, i'll help both of you out.
the ring seal is the seal the piston rings have on the cylinder wall. pistons have rings in them that contribute to the compression (look up pics on google), so before doing a t-trim i'd go ahead and check the compression in each whole.
itsblue95
itsblue95
Louisville Kentucky
well if i was to get this supercharger it would only be on the stock motor for a few months and only be running 8psi intil i get the other motor finished and then it would go on that motor
5litrarag
Brackets AND the blower outlet.... Fox has a different one I think. SN has that curve to it right on the blower housing. Better look it up first to be sure.
