JDwhite98gt
- Joined
- Apr 6, 2008
- Messages
- 1,285
- Reaction score
- 0
So finally got the last tax return check and it's time to buy tires. I'm going with Hankook Ventus V12 Evo's for my saleens. I have 305's now and my fender cuts them up so I want to try a 295 instead. After shopping around on discount tire direct these are the sizes I can find, but I need some insight on wether or not these are ok.
Front: 265/35/18
Rear: 295/30/18
Now from what I understand the 30 or 35 sidewall profile is a ratio of the width and you can turn that into a percent and multiply it by the width. For example the 295/30/18,
30%=.30, .3x295=88.5 (is 88.5 the height of the tire?) if it is then it will be shorter than the 265 ( .35x265= 92.75) to recap, the front will be 92.75 high and the rear will only be 88.5
So is this a problem, because they are not showing anything shorter for a 265 front tire and I want to stay with a wide tire in the front to help with handling. Thanks guys.
Front: 265/35/18
Rear: 295/30/18
