water pump stuck ?
killagt
Im doing PI intake swap now, and I having trouble remove the water pump, I did remove 4 bolt and accident brake one of the side of the water pump, using breaker bar, Im thinking getting new one any way, so I dont care wat method to get it out, please show me how.
Where is good place to buy water pump ( cheap and realiable is better ).
and about coolant nipple, I put a socket on it and hammer it, is that right ?
thanks
96gt226410
If you're doing just the intake swap, why are you removing the water pump? You don't have to. The nipple doesn't have to b replaced. You can just cut it to make it shorter. That's what I did. Then I used rubber hose and clamps. It's cheaper and faster. O0
K
killagt
Cause I want do it right way, I hate tear every thing down the third time.
