MoonlightGT
OK, my 96 GT runs a little hot in the summers here. on the temperature gauge the needle sits around the "M" or "A" on the "NORMAL". How can i help cool it down a bit?? im running a 192 degree (stock) thermostat, should i change it to 180? also i run a 50/50 mix of coolant/water. should i change it to 30/70 coolant/water?, will this help? can i run straight water?? what about a manual cooling fan switch so i can run the fans more often? HELP
