Weird sound during start up (video link)
pilks
Stupid video showing my recent installs, shorty antenna, and bullitt pedals. (quick revs)
Thought id share and see if anyone can help with the sound
YouTube
- Broadcast Yourself.
(around 14-16 seconds you can hear it and then again at 2:19 i believe)
sound occurs during start up, sound like a clicking or chattering. Seems to be coming from under the hood, and i have no idea what it is.
1998 GT coupe
5 speed
38,000 miles
catted x
catback
no engine mods
thanks all
pilks
pilks
also check engine light is on
p1445
purge flow output high
maybe that has something to do with it?
silver 4.6
hm... im no engine guru but it could be the starter spooling down? i know on my dads avalanche the starter makes ticking noises after the engine starts.
JerZeyStangz
Northern NJ
Sounds like either the starter which is stated, or pulley system in on the engine, I know when they do not move for a while they tend to make odd noises.
vermilion
maryland
pulleys would have a whining noise. thats like a piston disengaging horribly. a pinging marble.
wnracing
That was my guess too. Like I told him @ MB my Mountaineer does basically the same thing, but only when it's cold. My mountaineer came from Michigan so it has some surface rust on the underside and the Starter is probably beginning to see the effects of that.
Vid of the Mountaineer. Really does it @ the 50 sec. mark.
YouTube
duff daddy
only way to find out is here....
1) take off the serpentine belt and start the car see if the noise is there...
2) pop start the car :) you dont use the starter and if the noise is here you know its NOT the starter...
wnracing
Yep, that would be a good way to test it. In my case I know it's not the belt, I already got some belt dressing and checked it. Plus considering it were a problem with the belt, chances are that the sound would be faily constant, not only when the car starts.
pilks
pilks
Yeah I can see it being the starter, iv had the car since June 09 and the belt has been replaced. The battery terminals have zero corrosion, and the sound only occurs at start up. Thanks for all help dudes.
duff daddy
it may not be a belt problem BUT a pulley problem ie p/s pump when real cold or first started will suck some air in and then cause a noise.... common with caravans :)
pilks
pilks
something i need to be concerned about???
car is not a daily and will actually be garaged until May 1st, when insurance gets put back on
ThePope
I had the same problem with my 98 GT. I replaced the pulley on the tensioner and the pulley just above it.
silver 4.6
actually dude... the last time i posted i didnt listen close enough.. i have that exact same noise.
pilks
pilks
and what happened???? what did you do about it?
cobraclone
starter. mine did it for 6 month, then it stoped for 4 months , its a random thing . and yes only in cold starts , but a visual inspection of starter was fine
