what can i do next?
93PGT
any ideas? maybe plenum and udp's? is there anything better for the $
96sohc
I wouldn't do either. If you want to put the squeeze on it I'd save for that.
93PGT
has anyone used a lower chassis brace or subframe connectors?
96sohc
Subframe connectors are an awesome idea if you don't have them already. I notice you have a 5 speed and don't mention anything about a shifter; thought about that?
I have Griggs SFCs and a Steeda Tri-Ax, I like them both and would strongly recommend them.
Magic
Some time zone
If you still have the stock plenum with a 75mm TB, then definately an upgrade to an aftermarket plenum will help....or port out your stock plenum....
Accufab, Dragon, and Trick Flow plenums are pretty good.
WarHorse
Ide do the subframes, or a short throw shifter next.
in my opinion just about any mod is worth the money, if you plan on keeping your car for a long time, start working on the suspension, K-member, LCA's etc.
GDawg
Don't forget C&L...
MGW short throw shifter is sweet with custom knob.
LCAs
Show us some pictures...
93PGT
i have a short throw already and the suspension is already done. i just found out that my extra plenum was ported, i just need to figure out my winter plans for the mustang before i buy the paint that i need
