What grade?
g36 monkey
Orlando, Fl
87 is all you will need if you are not supercharged or turbo'd.
however, I am going to be getting tuned for 93 to advance the timing a little more when I re-tune with my long tubes and no cats.
JRad405
Central NJ
87 for me because I see no point in spending more for the little power I would probably create in my case at least. I DD my car too so it just would make it worse on my pockets. I only run 93 when I go to the strip with the canned tune from Bama.
robb15033
Northern Va.
You need to use 87 octane in a stock car. When a SCT tuner is using created files then that changes.
If you use 87 octane and have pre-combustion issues or performance issues, most probable cause is dirty upper intake (Seafoam it!) or ignition coil/spark plugs.
MadStang
Escondido, Ca
now that e85 has become more readily available if I still had my sixxer I'd be running a high compression e85 motor lol
Chump
Chump
TX
Yeah I was just wondering if I used premium if I'd make more horse power.
MadStang
Escondido, Ca
you won't make more power just from running a higher grade fuel. you need to be tuned to take full advantage of the extra octane the fuel will provide.
i put in mid-grade, as that is what my owners manual told me to put in (87 octane)
no need to put anything higher without raising compression or adding a power adder.
i would put in premium when running injector cleaner, as well.
stangdriven
that is true... bout the higher grade fuel... ill back that up also... gotta tune for the full advantage.. besides having higher compression...
