what is it?
dwight94
ive got a 94 cobra, and through the 1/4 im running right at 6100 rpms in third crossing the line on 26x10x15 MT slicks...is this a 3.55 or what
you should have 3.08's, the only cars that i know that came with 3.55's from factory are, the Mach1's and 03-04 COBRAS.
check on the rear axle for a tag on the differential, if gears havent been changed.
dwight94
its been took apart before its got bbk control arms and a differne t diff cover
blown98gt
if you need to figure out your gears then its (rpm x tire height), divided by (336 x mph) as long as you are using 4th gear in the tranny.
gt96stang
jack up the rear of the car.... Mark the driveshaft and count the number of times it goes around per full revolution of the rear tires.
ProKiller
PA
exactly
