what is needed for GT to Mach1 front brake install
98GTnSC
i may pick up some Mach 1 Brakes for the front of my 98GT. just wondering what all i will need to do the swap? drilled and slotted rotors, pads, calipers, and brake lines. anything else i will need? and also if anyone has a write up on ow to do it thanks
Mustanger
Southern Oregon
I think the Banjo Bolts might be different threads also??? Anybody know positively? One is Coarse thread & one is fine thread...
Mystic SVT
^^^I think you're right on the banjo bolts being different. OP, make sure you get the caliper brackets bc if not then you won't be able to mount up the calipers.
mustang1
Seems like the only thing youre missing is buying the calipers off of me once I hit 100 posts. I have all of that plus the MC upgrade from MM. I never had more than 30 min to myself the last 5 months so im getting rid of em.
Mustanger
Southern Oregon
Hi what MC upgrade parts do you have? Pics or the MM part numbers...I need those for my upgrade...thanks, Walt
ReplicaR
MC upgrade is only required for 94-95 cars. Mod cars are using a completely different system, and their factory MC is sufficient enough to use Cobra/Mach1 brake kit.
