What Rear fluid
1BAD96SVT
Im looking into changing my rear end fluid to royal purple on my cobra,how many quarts to i need and what weight should i go with..?
riored96gt
SoCal 909
When I swapped to Royal Purple in February, it took just over 2 qts...
Don't forget the Ford traction Modifier!! $5 at a dealer
Maniak87
is the modifier needed? i am assuming yes... what weight royal purple did u go with?
riored96gt
SoCal 909
Yup...75-90.
No need for 85-140 unless you're road racing.
Without the modifier, the trac-loc won't, consistantly.
(I could do without the smell, though!)
1FastGT
what does the friction modifier do? sorry im a noob never knew this existed.
MeanGrn Gt
friction modifier is needed for the trac loc (limited slip) in the read end. without it the clutches wont function properly and you will be doing :eek:utofcloset: one wheel peels
Conechaser
RioRed96GT said:
Yup...75-90.
What happens if you use the 75-90 for the road course instead of the 85-140?
birel21y
If you use the thinner oil, its just not as much protectionon the ring and pinion. Your full throttle alot of the time, and the ring and pinion are turning crazy fast. More heat = thinner of oil, to compansate, use a thicker oil to start.
Same reason why we use 15-40 oil for the engine.
