what wire to tap into for inline pump?
showoff
I need to splice into the signal wire for the stock pump,so I can run my external pump. Anyone know which wire it is? 95GT
From ccrm to inertia sw- dg/y (dark green/yellow)?
inertia sw to fp- br/pk (brown/pink)?
so says all data
showoff
so says all data
thank you for your help
Paul
I believe he's speaking of the plastic connectors that wrap around the wire, piercing the insulation in order to get current - as opposed to a proper cut/strip/solder/heatshrink.
Paul.
modo
Philadelphia, PA
showoff said:
Paul.
the anal paul way. LOL
no that is the correct way.
i would also use a relay and run a proper new power feed directly from the battery post or the starter solonoid on the fender. give it a fuse as close to the power source as possible and have a breaker close to the fuel pump.
solder everything, no crimp connectors, heat shrink
showoff
modo said:
showoff said:
Paul.
already done.i just wanted to see if it was the same wire or not as my old fox.
