Wheel Fitment Help
Carnage281
Texas
So I'm looking to be purchasing some wheels pretty soon and I'm not 100% sure they will fit as far as back spacing is concerned. The wheels are 18x11 with a 74.1 center bore and a option between 15 and 25 offset. Which offset will fit without sticking out past the fenders?
Carnage281
Carnage281
Texas
Wow! Will they actually fit under the fenders?
From what I have read 18x11 wheels can fit if they have the correct offset, but so far I haven't seen what that correct offset is. Was hoping some one here knew.
sleepn_sn95
Indy
What tire are you planning on running and how flush do you want to be? An 18x11 +15 would get you pretty damn flush with the fender and a roll/slight pull would be necessary. An 18x11 +25 would bring you in from the outer fender but would be close on the inside fender/exhaust clearance if you are running meaty tire.
chris91
Cincinnati, OH
My 18x10.5's with +22 offset are damn near flush. My 295 BFG KDW's are rubbing on bumps so I have to roll the fenders. Personally I wouldn't go with a +15 with a 11" wheel. They will poke out on a new edge. Gotta remember sleepn, new edge cars have wider rear ends.
Carnage281
Carnage281
Texas
[MENTION=10867]sleepn_sn95[/MENTION] So far it's looking like 335 tires. I would get 315 but I can't seem to find any that aren't drag radials that aren't about the same price as 335 tires. If it can I'd like it to be flush with the fender. Thanks for the advice.
[MENTION=9338]chris91[/MENTION] I think I'll go with the +25 . Like you said new edges have wider rear ends, and I also got rid of my crappy quad shocks so it should be plenty of room. If not I can always use spacers since the wheel will sit farther in.
Thanks for the info guys, really needed that intel lol.
chris91
Cincinnati, OH
Be prepared to roll your fenders. I just picked up a no name roller that is almost identical to the Eastwood one for $70 shipped on eBay. It's nice and came with a year warranty too. What wheels you going with?
Carnage281
Carnage281
Texas
These bad boys right here. Esm 007
stillridin
