Which Fel-pro head gasket do I use?
gnx547
I have stock 302 block with Edlebrock heads and which Fel-pro head gasket do I use? There are many to choose from. There is a 8548 PT2 (which is for a Windsor) 9333Pt (which is high performace) and 1133, 1134, 1011. Which gasket do I use? What head gasket do you guys use?
Addermk2
1011-1 and -2 are prone to blowing out the fire rings. The 9333 also seals better.
blackpony
I have made over 850 rwhp using the 1011-1 gaskets on a 408 with a 300 shot fogger kit. When the surfaces are prepped correctly and the heads are torqued correctly, they are a great gasket.
gnx547
gnx547
Before I reinstall the cylinder heads I need to remove the old gasket material. When cleaning up the cylinder head, what grit sand paper should I use to remove the old gasket material and smooth it out?
