which h/c/i
i_love_my_stang
on my 94GT keeping the stock bottom end, which h/c/i is gonna give me the most power i want to meet or exceed 300hp which combo should get that?
Ninety5_5Ohh
The tfs twisted wedge kit should get you there. Might want to make sure the heads have ptv clearence
LAFENATU
Combo that has proven the most gains: Holley Systemax II, AFR 165's, Ed Curtis Custom Cam
However...the TFS Top End Kit is a VERY good setup for the price.
95PGTTech said:
a procharger.
Vortech > *
I
i_love_my_stang
h/c/i is cheaper then a supercharger lol might get a blower when im 30 and have money, hows the holley hci compared to the tricflow?
LAFENATU
I would get the TFS kit over the Holley Kit.
The FTI (Ed Curtis) setup is nice and powerful, just cost is a little more than the TFS kit. Then again the FTI kit is comming with a custom cam for that setup vs an off the shelf cam from TFS.
All depends on cost. Do you have rockers etc already and need JUST the Heads/Camshaft/Intake Manifold?
LAFENATU
Well then it falls down to cost.
I am not a big fan on Twisted Wedge heads, they do make power but I prefer AFR over TFS. The Trick Flow kit IS hard to beat for the money. It comes with everything needed. Rockers, pushrods, timing chain, gaskets etc.
LAFENATU
i was thinking of piecing something together since i'm never gonna save up 3 grand
Well, I like the first combo I told you about.
Flowtech Induction which is Ed Curtis' company. He does a Edelbrock Performer RPM or Holley Systemax II, AFR 165, Custom Cam combo that most usually net anywhere from 300-315ish RWHP.
If you do a search on Corral.net you'll see all the people that have gone through him.
LAFENATU
$300.00
He designs them and the actual shaft itself is cut by Comp Cams for him.
teedub
Greetings, One combo I had was TFS Twisted Wedges and Street Heat intake, stock cam 1.7 rockers full length headers and an AOD. It made 267 RWHP. Just for reference.
I
i_love_my_stang
humm wonder what that would make with a cam and 5 speed
mikey94gt
299RWHp, 344 Tq, with a 73mm C&L maf, 75mm throttle body and 30# injectors, MSD ignition thru my 5 spd, and stock gears on 18" wheels. Im running stock bottom end, but I put the Total Seal gapless piston rings in and opened up the bearing clearances, installed a main stud girdle and put in new Crane Cams heavy duty roller lifters. it also has the 88 Gt bottom end, not the 94, and its zero decked as well. I also had a pretty serious clutch and an aluminum flywheel.
This is with the Street heat top end kit from Trick Flow.
I
i_love_my_stang
nice, i think im gonna do a holley intake, afr or trickflow heads and a custom cam, ill get the heads ported and decked as well
95PGTTech
HP/$, the blower is the better buy. You're going to be hard pressed to make 300whp on a stock shortblock 302 and still retain a nice driving car. Not impossible, but not free either.
