Which valve spring setup with steeda #19 cam???
birel21y
ok guys, so i decided on the #19 cam... so what valve spring setup should i go with? Steeda sells a kit for $135 with springs, retainers and locks. What would you recomend? Thanks, Alex.
LAFENATU
Why would you need new valve springs?
Your sig says you have TFS valve springs. TFS valve springs are the best bang for the buck. They are good up to .550 lift AND they have chromoly retainers...
B
birel21y
I just wasnt sure if i needed to match the valve springs with the cam i going with. i just dont want to float the valves.
Steeda #19 - 220*/226* - 280*/286* - .480"/.480" - 115* - 2,300-6,000 RPM
1.6 Roller Rockers
Intake Opening: 26* BTDC
Intake Closing: 74* ABDC
Exhaust Opening: 79* BBDC
Exhaust Closing: 27* ATDC
Recommended Valve Springs:
110lbs closed/312 lbs open
