White face gauges - how to change them in your instrament cluster
Dalamar
Dalamar
SLC, UT
ORLY? if you take them out, I'd like a picture of the back of them please! :)
Matt94GT
Jeff there is a picture in the other thread I think, the one that talks about changing to LEDs....either that thread or the one that someone started in the garage
mach1197203
If you go to www.superbrightleds.comhttp:// you can buy a 194 single led that has a 120 degree bowl on the tip of it so that you get an even light spread. this is what i put in mine. they are dirt cheap there and the ship really fast.
Dalamar
Dalamar
SLC, UT
mach1197203 said:
If you go to www.superbrightleds.comhttp://http://http:// you can buy a 194 single led that has a 120 degree bowl on the tip of it so that you get an even light spread. this is what i put in mine. they are dirt cheap there and the ship really fast.
Excellent point, I got some and need to swap them out. figured it would help with the bright spots.
Do you have a picture of how yourse turned out.
Dalamar
Dalamar
SLC, UT
bump
does anyone have an picture of the light output using the 90 degree bulbs?
just curious, as I havn't done mine yet.
JiMi_DRiX
Tucson, AZ
Where did you get your white face gauges at? I like how yours look. Many of the ones I see look real cheap and cheesy with the font and style they use. Yours look more like the stock Cobra ones :)
Dalamar
Dalamar
SLC, UT
I got them from UPR, but they don't seem to have them any more.
just those reverse glow pieces.
it was a silver gauge face.
Dalamar
Dalamar
SLC, UT
That would be them.
your searchabliity is bedda than mine I guess.
JerZeyStangz
Northern NJ
I have done this mod, and have the LED's mentioned in TxCobra instructional thread. Here is what your LED's suppose to look like with white & black (stock) face guages..
White
Black
JiMi_DRiX
Tucson, AZ
So I keep hearing two different things about the bulbs and getting the lighting to be even. Which is the CORRECT bulb? Can someone post a linky?
JerZey, that looks very nice! Which bulbs did you use? and are they the "cool white" ones? That is SO much better than the nasty green stockers!
CanaryGT
Phoenix
The back of the stock gauges are actually Thicker in parts. Thats why the light output is even...
Zgadson
Finally found the reverse glow gauges I liked, so I got 'em. I don't like the gauges where the whole face glows, that looks boring. These look just like new stock Ford gauges. Here they are installed.
JiMi_DRiX
Tucson, AZ
White
Black
The light output is PERFECT. I wish mine were like that...
Suprasuavy
