White smoke wot
Project Grey94
Wide open throttle from about 2800 to 5500 white smoke smells like oil engine pulls strong but white smoke wot and no smoke normal driving help please thanks
muzzy25
new zealand
is your brake fluid going down?
i had a car that was sucking brake fluid through brake booster into engine causing white smoke on acceration?
Project Grey94
Project Grey94
I'll check in the am did you figure out what was causing that problem? Thanks for you're time
Project Grey94
Project Grey94
Blow by, valve seals, improper pvc or catch can routing. Can be a number of things.
Could you explain the blow-by and valve seals leaking oil not too familiar and is this something that you can do at home thank you for your time and information greatly appreciated
tinnocker
If you are going to be putting money into these stock heads, now would be the time to spend that money on some gt40 heads off an Explorer or a set of aluminum heads. A little extra horsepower never hurt anyone. Just something to think about.
