Who makes these?
CompOrangeSN95
North Jersey
Anyone know who makes these? I need bushings but don't know what ones to get, I ordered a set from summit assuming I had stock control arms... I don't. They have no markings on them. Any ideas?
old bushings...
ReplicaR
Kinda looks like BMR. I don't know if they still make stuff, but I remember they were the hot ticket back in the day for Fbodys and such.
CompOrangeSN95
CompOrangeSN95
North Jersey
I just need bushing for it and knowing who makes them will make that a lot easier, I might just measure the OD and ID of one of the old bushings that isn't torn up and order them straight from energy suspension.
wytstang
That was the first thing that popped into my head but looking at a pic of the lca the sway bar mount has a rake to it. The ones posted and Hotchkis don't.
http://www.lmperformance.com/4085/50.html
Latemodel does have one that looks close to the ones posted. I just can't see the sway bar mounts
http://www.latemodelrestoration.com/item/LRS-5649B
jwyche
I have had a set that looks just like those and they came from Profession Products. My guess is there's a manufacturer in Taiwan or India set up to make them for everybody. They either paint or trade mark them and shoot them over.
Jim
BTW, check the welds on whatever you get. I read an article not long ago about some overseas manufacturer using Bondo-like body filler to hid bad welds...get this now...on K-Members!!! Those products were sold here before someone discovered it.
badass98svt
I know, those are gonna be damn harsh. But then again, he removed them from his car so they were already on there. If anything. they'll be a smoother ride with the new bushs
badass98svt
In that case, I'd go with different LCAs. MM makes a great piece with solid bushings on both ends.
poly isn't too great for a track car.
CompOrangeSN95
CompOrangeSN95
North Jersey
It will be perfect for my application (road course not drag) If I put solid bushings in it, I run the risk of damaging my rear end
jwyche
A big X2 on this! In my 1992 I've had Factory Five LCA/UCA for years. Last year my car started wandering all over the track. It scared the hooty-hoo out of me. Found that the urethane bushings were mush and swapped them for the aluminum bushings.
Talk about a difference you could feel immediately. The first time I launched on the hose, they bit so hard it snapped the input shaft on the Tremec 3550! You can see the carnage and the repair on my little website.
The red car was hitting 1.58 -1.59 short times but with the aluminum bushings, and after the transmission repair, the times dropped to 1.54 - 1.55 consistently.
Those hard bushings make any control arm work better, in my opinion.
I'd be more worried about the rear end wandering around on urethane than tracking straight and true on aluminum.
http://s273.photobucket.com/albums/jj240/jwyche_photos/?action=view&current=FiveLengthSpot.flv
Jim
