Will a termi T56 fit??
BlackCobra50
Wanting to convert to a T56 because I HAATTEE T-5's. Will a T56 out of the termi's work? What all will I need?
El_Diablo
new bell
custom transmission crossmember
t56 shifter
new clutch
new yoke
shorter drive shaft
more to it but thats just a short list that i can recall off the top of my head
El_Diablo
are you sure about that? i dont believe ive ever seen one like that?
(t56 on right, pulled to swap for the 4r70w on the left)
snoball
El diablo.. odd question but did the yellow car come from missouri??? 99gt with a 01 built cobra motor with a procharger on it??
GearGambler
Northeast PA
here is what you'll need:
custom trans crossmember or move the crossmember mounts
transmission mount (if the trans doesnt have one on it)
quick time makes a bell to install the T56 on a windsor block.
i dont think you'll need to change the clutch unless the t56 had the input shaft upgraded to 26 spline (which is a good idea!)
you'll need a driveshaft specific to this application or to modify the length and install the correct yoke on it
shifter (MGW all the way!)
not sure if anything needs to be done to the speedometer cable.
2slo95fiveoh
Lawrence, Kansas
OnyxCobra said:
It's just what i've been told multiple times, maybe they were thinking about something else i'm not sure.
I think you are thinking of the 96+ 5 speeds (t45, 3650, etc..) that are all one piece...
The T5, TKO, and T56 all have separate bellhousings from the trans housing.
B
BlackCobra50
^ Are you 100% sure about that?
If I can use the T56 out of an 03/04 Cobra than thats what I'll be looking for since they'll be cheaper than buying a brand new tranny.
El_Diablo
yes, biggest hurdle is the bell, price of trans and the custom cross member that you'll have to make
LAFENATU
Why?
The TKO 500 will take more abuse. If your willing to go through the BS of doing a T56, get viper spec.
