will these tires fit 18 x9?
ReplicaR
Technically, they will fit over the wheels, but the sidewall is going to be too small on the tires, and you will end up with a shorter wheel than stock ratio. With stock ratio wheel, whether it's a 15 or 16 or 17 inch rim, the tire height always ends up being 25.6 inches tall. The tire you mentioned is a 24.4 inch tall tire, so you're going to end up losing circumference and therefore your mileage is going to suffer and your speedo is going to be off.
R
rideorange812
thats confusing because the guy at the tire shop got me nittos nt555 for my 18x10 in the rear but that wheel is on back order but i can get 18x9 all the way around. so wouldnt it be to wide as well?
ReplicaR
I'll simplify it for you. The tire you should be running on 18x9 is a 275/35R18.
Spd0lit
SoCal
No, you are not understanding he is saying that if you get that rim you should get a 275/35/18 all around if you went with an 8 inch wide wheel in the front then you can run a 245 width.
