window going up to far?
1FastGT
my passanger side window seems to be going up too far and putting alot of pressure on the glass and doesnt seem to seal very well either. anyone else have this problem. i dont wanna shatter my window. ugh :angry7:
eliyarbrough
Nocona, TX
I had to replace my rear 1/4's window motors. The POS place put the glass in wrong! It stayed that way for maybe 1-2 years. I could roll it done enough so it would be right. When my conv top opened on its own, I added that to the list that needed to be corrected! They were just about 1/4" too might, I;m guessing. I took it to the losers who f'd it up. They said it was just fine. Every time it would get wet, it seeps water in though. It's perfect now though! Has it always been too high? Or did it just start being this way? I cannot answer either question, just thought it might help the others.
GDTrumbo
Nashville, TN
Seems there are 2 window stops at the top of the window's travel. These stops have rubber pads that, with age, tend to fall off and end up in the bottom of the door. This will cause the window to travel upwards too far, or crooked at the top. You might pull the inner door panel and see if one or both have come loose.
GT
1FastGT
well i just bought this one and the passenger side window is the only one thats doing it.
yeah my drivers window goes up a touch too high too. I heard there's a way to adjust where the window stops but the process escapes me right now.
