Winter's coming... Projects?
Paul
I live in Phoenix, so winter is a much better season to work on my car since it's not 120 degrees in my garage.
I plan to:
- Finish up the paint in the trunk, re-install the battery box and cut-off switch, get some carpet or other stuff in there so it's looks finished despite the giant new wheel tubs.
- Finish installing all the damplifier sound deadener in the car, install the rest of the interior, except perhaps for the new "back seat solution" since I'm not sure how I'm going to do a rear-seat delete with the mini-tub in there, while retaining a "streetcar" look.
- Get the suspension set up at least close. I need to adjust all the coil-overs and get the car sitting correctly.
If all the planets aligned, maybe I'll try to get it fired up too. We'll see.
Paul.
alex302
Florida is not bad on winter but, I'm going to install coilovers all four corners and tubular control arms maybe some sway bars if the buget permits.
Musturd
Turbo kit to finish my car and finally be done with it been a long time since I drove the musturd car
97stanger
^and than that turbo wont feel like a lot and you'll want to up the boost lol
03DSGGT
SN95 Supporting Member
Akron, Ohio
Well this winter is gonna be focused less on my car and more on my buddies car. He just bought a 96 Tangerine GT vert. that needs some TLC. So Im gonna do some maintenance work on it, then PI intake/cams, and the usual boltons. Then once I get done with that, Im gonna do a couple things to mine. The plan for mine is:
Drop the gas tank and rear end out of it
Do a PPRV delete in the fuel tank
Plate and weld up the upper torque boxes
Install my Baseline relocated upper control arm kit
Install my Strange axles in the rear end
Delete ABS/install ABS delete manifold from Phil
Install 3" studs all around
Sell my rear Prostars and slicks and buy new wheels/tires in the correct size and backspace
ProKiller
PA
-wilwood brakes up front
-front and rear bumpers
-paint front/rear/T1
US Soldier(stang 98)
Dixon IL
my winter project is prolly going to be new rims n tires, im pulling off my valve covers n timing cover cause im having my friend Ron the owns twisted visions hydro dipping. dip my valve covers n timing cover. im going to replace my alternator might do a coil over swap on my plugs, n to top it off i may try to get some termi seats.
97stanger
My car was down for 2 and a half years without me driving it and I have 900 miles on my new build and I already want to start putting it down again and changing things for more power lol
TurboDSM
My plans are to PI swap the mustang, and hopefully start on this
clark98gt
Pennsylvania
I broke my t45 in august so my winter started early. My plans are 5.4 swap( which is already underway), upgrade the trans., and hopefully turbo kit with all of the supporting hardware. I started working at a gas company a few months back called Stallion and apparently winters are pretty busy so if I'm going to work my life away I might as well get some cool stuff for my car. lol
96GTPlanB
Staff online
