Wireing help
SMOKEDYA
Tucson Az.
As some of you know,i'm doing a wire tuck and bay smooth as well as doing a new motor for my 94. I'm also converting to a fox body style TB. So I got the car no motor trans and i'm kinda going into where what wires go where blind. I do have a good knowledge of where they go but I do have a few questions. Here are some pics of the few wires I have for now.
This is coming down the front of the block on the driverside. The little black one I assume is for the oil sending unit? Whats the other one for?
This one is next to the dizzy and I know the brown is the coil,what is the green wire one to and also the little black one
The one on top is for the temp sender. Look down on the intake next to the dist and you should see it.
The green one is a capacitor on the coil. The big black connector in the 1st pic goes to a sub harness to the O2 sensors and possibly starter. IIRC
Tony
ohio
hahaa, i use to wonder wtf IIRC meant.
sorry carry on :undecided:
Will a coil off a fox not work? What is IIRC?
It will. Just don't plug that in. Probably a noise filter of some sort. I think its actually mounted to the coil bracket.
