Would it be too much?
schacher94gt
Im going to forge my 98 cobra motor this winter and having trouble with what compression I should go with? Stock is 9.85 but I wouldnt mind bumping it up to say 10.3 at max and ill be running 10 psi of boost. Too much compression? I could stay with lower compression and up the psi but than id have to intercool it. Im low on cash right now so I figured Id just up the compression since I have to get new pistons anyways.
snoball
That is a big myth. As long as you keep it from detonating and the tune is good, bumped compression is fine. You can make the same amount of hp with less boost with higher compression. Likewise if you had lower compression, it takes more boost to get to the same power level, therefore making the blower work harder and not efficiently.
Now Im not saying you can run a ton of compression but look at the new 2011. It comes with 11:1. Making over 500rwhp safely. And the rods and pistons arent forged.
http://www.youtube.com/watch?v=SDQZOM4lufI&feature=related
http://www.youtube.com/watch?v=04V_f9hOCCU
schacher94gt
so on a fairly conservative tune i should be fine. One problem that might come up is that the highest octane available around here is 91, I should still be ok though?
As of now the car put down 473 and id like to bump that up past 500, is that possible doing a higher compression, 10 psi, and running a conservative tune?
snoball
Id look into a methanol kit,itll help in the hp department big time. Check with your tuner to see what he thinks about 91,Youd hate for it go lean from bad gas. There is a good topic on modularfords about bumped compression on 4v's, try doing a search for it, I cant find it currently. Its like 20 pages long. Tons of info.
96_SVT_Cobra
SN95 Supporting Member
Orlando
i made 543 rwhp on a non intercooled t-trim with 9.2 compression. my tune was really soft as well since my iat's when i was doing that were around 190*.
schacher94gt
how many pounds where you pushing?
See im also going to add LTs so thatll really help the 4v breath
96_SVT_Cobra
Orlando
just about 15psi. i have ported heads with fr500 cams for heads. but i am still on the stock exhaust manifold.
schacher94gt
vortech highly recommended it
but if you can do it i wouldnt mind running the same compression, if not taking it down to 9.0, and running 15
96_SVT_Cobra
Orlando
of course vortech did they want u to buy their crappy aftercooler. but there are ppl running well more with none but on a street car it would be safer with one, sure, but not their 1500 dollar aftercooler set up. if i was u and wanted only 10psi ish and higher compression. id do that and get a really good meth kit with progressive spray. like the alcoholinjectionsystem stage 2 setup. that would be ideal. and you will get well more power since meth will actually make the 93 octane burn like race gas allowing u to turn up the timing.
schacher94gt
thank you for the info, best so far
tuesday my buddies termy get dynotuned so ill talk to my tuner than and see what he recommends and what he could do for me
duff daddy
If your building this, good luck and have fun with the temperment of an aluminum block with quite specific tolerances and teardown and build procedures.
schacher94gt
ill be taking the motor out and putting it in but i dont want anything to do with actually putting it together haha
duff daddy
ahhh hope you have a machine shop who has done work with teksids prior. eitherway man good luck and hopefully its runing before mine.
schacher94gt
im going to call around. heard there was a good shop just north of here. Im hoping for march/april time, but in no rush. Just started a lil tear down so i can get my internals ordered
vermilion
maryland
almost easy 4-500$ dollar prep work. ask me how i know.
align hone.
torque plate boring.
and super slick decking the block for standard MLS gaskets.
i have ported pi heads and NVH/WAP block. same ideals as teksid block.
schacher94gt
ya im thinkin its gonna be cheaper just to buy a dss shortblock bc they have a the arp bolts and would just need to slap the top end on and wala ( of course not gonna be that easy)
