five lug conversion
pistolp86
okay, the rear should be easy enough, but what im wondering about is switching from fox four lug in front to sn95 five lug in front. im buying a tubular k-member so you have to use tubular a arms as well. the only tubular a arms i've seen are for foxes which means you have to use the rotor with the bearing inside. I want to switch to the sn95 style which you can just buy the rotor when doing a brake job, not have to redo the bearings every time i take the front end apart. Does anyone make a conversion kit for a fox to sn95 style brakes, not just a five lug conversion?
alleghenyamerican
