v6 vs v8 transmission
thatsnninety5
I went to the junkyard and got a 4r70w from a 97 v6 mustang. mine is a 98 GT. Will it work with my car?
thatsnninety5
thatsnninety5
No. The bell housing is wrong. It’s the wrong bolt pattern and the starter bolt pattern is wrong.
What about a 4r70w in a 96’ GT. Im assuming the belling housing matches up but will it be plug and play with my 98’ ?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Not entirely. The electronics in the 98 are different. For the 96 to work, you’ll need solenoids and internal transmission wiring harness for a 98. Then pull the valve body down to swap it all over.
96blak54
In the shop
Yea the v6 trans still had the old pushrod bellhousing pattern.
Hey what about an automatic from a 99 or 2000 GT? You know, just trying to figure out what will work to open up availability.... would they swap in easy? No electronics swapping and such?
lwarrior1016
South Mississippi
Valve body would be alright, but the output speed sensor is wrong. Vss opposed to Oss. I think you have to install a converter box to make it work.
Suprasuavy
