01 abs light question
carbuff
My 01 v6 has an abs light that comes on sometimes and other times stays off. No real rhyme or reason to it. Ive scanned the system with forscan light and when the light is on it says it cannot communicate with the abs system. When there is no light it all checks out as good and passes the scan. Now if it was a bad wheel sensor would it tell me that? Does the 01 system have that capability to tell me if and which wheel sensor was causing the fault? Would the non communication message point to something other than a bad wheel sensor such as bad wiring or a faulty abs pump/unit? Since it is intermittent possibly a dirty connector at the pump?
07GtS197
Naples, Fl
Check the connector to the abs module. That era is known for its flaky Bosch abs pumps. I had one go out in my 02 Gt. I forget if I checked codes or not but the abs and traction control off light would light up. My issue wasn’t intermittent though.
carbuff
Thanks. I will definately check that connector. I was just wondering if that era abs computer was capable of telling you what the actual issue is or if its just a pass/fail type of thing.
There must still be some way to go old school and read the codes to check. On my 94 you can use a paperclip to pull codes by counting the flashes on the abs bulb. Youtube shows how, maybe see if it does for yours and try that out.
07GtS197
Naples, Fl
Nope the abs can only be read by a scanner capable of reading abs codes. Op I suggest getting an elm327 dongle with the Forescan app. It can read all modules and codes from all of them not just the ecu codes. That should be able to tell you what the issue is.
so ya can't do this on 01?
also I remember reading that the abs light will come on if the brake fluid is low. check the reservoir and see if it needs a touch.
carbuff
Hi, sorry for the delay. Ive done the elm327 thing with forescan lite. It will either pass the abs test with no codes or say that it has no communication with abs module. Im told that this means that the module is failing, a very common issue. Im currently in the process of removing the module and will probably send it out for refurb for 100 bucks. Ive got the bracket removed and now just need to remove the 6 torx screws that hold it to the pump. It will probably take a while to do all this. I will update when progress is made. Thanks to all.
Techedz
