Venomous96Cobra said:I was looking into one of the newer ones with the 8cyl! they have alway's appealed to me but I also have never gotten one.... I think they would make a very nice daily, but as someone said parts are hard to find for the older ones and very expensive!
JiMi_DRiX said:Venomous96Cobra said:I was looking into one of the newer ones with the 8cyl! they have alway's appealed to me but I also have never gotten one.... I think they would make a very nice daily, but as someone said parts are hard to find for the older ones and very expensive!
The new 2010 SHO's dont have a V8, its a V6 EcoBoost, twin turboin other words... lots of fun! haha.
DO NOT, I repeat, DO NOT GET THE V8 taurus! It is one of the biggest failures in latemodel fords.Venomous96Cobra said:I was looking into one of the newer ones with the 8cyl! they have alway's appealed to me but I also have never gotten one.... I think they would make a very nice daily, but as someone said parts are hard to find for the older ones and very expensive!
Unlike the SHO V6, the SHO V8's valvetrain was an "interference" design, one that is shared by many engines built today, meaning that the piston will collide with the valves if the camshaft or timing chain fails. Due to some cam sprocket failures, the engine acquired a reputation for potentially catastrophic failure.
[edit] Cam trouble
Soon after the introduction of the SHO V8, widespread problems with the cam sprockets began to surface. Ford had used a relatively unusual method, called "swaging", of affixing the cam sprockets to the camshafts.[2] The cam sprockets were fastened to the hollow camshafts by forcing a metal ball which was slightly larger than the interior diameter of the camshaft through the center of the camshaft, thus expanding the metal slightly and creating a mechanical bond between the cam sprocket and the camshaft.[3]
This method proved to be inadequate, and the cam sprocket could break loose from the camshaft and spin independently from the camshaft (or "walk").[4][5] This would result in the camshaft stopping and thus not activating the valves, allowing the pistons to hit the valves, ruining the engine. The preventive measure of welding the cam sprocket to the camshaft soon proved to be a fix for engines that had not suffered such a fate yet.[6] Another such fix is "pinning" the cam sprocket, or inserting a pin in the sprocket to keep it aligned on the camshaft. Ford issued a TSB (TSB 03-14-1) prescribing the application of Loctite to the cam sprocket to lengthen the life of the camshafts,[7] but as SHO owners have experienced cam failure after the application of Loctite,[8] most SHO enthusiasts do not recommend this fix.[9][10]
joekd said:I owned a 93 3.2 ATX SHO way back when, as mentioned great car when it's running right but repairs are very pricey to the Yamaha motor
Make sure the valve lash adjustment has been done or thats going to be your first big expense
Here is a lot of good reading for you http://www.shotimes.com/php-bin/
Win said:Agreed. I had an old roomate that had one and that thing would move even with the Auto.
CanaryGT said:Valve Lash eh.... How much would that cost?
