1994 Cobra AutoX Build
Pleasanton/Hayward, CA
Got it really cheap lol. I thought about doing it for awhile, looked into it alotttttt but decided to stay SRA cause cheaper.
yeah but for how much i can possibly get an irs for it far outweights the sra route i would want to go because i want the 99 04 sra because it is that much longer lol
codfod
codfod
SoCal
Acquired some things today, Enkei NT03+M 18x9.5 fronts (+27 offset) and 10.5 rears (+30 offset). Rear offset isn't quite what I wanted it to be, as well as it being a staggered setup but I got a good deal so it'll do for now
Magic
Some time zone
I fancy those NT03 Enkei wheels....Rear offset might be good with an IRS or 99-04 SRA swap,since the rear end is wider than a 94-98 SRA.
Post some pics on the car!
codfod
codfod
SoCal
I have an inch spacer on the rear right now for the R58's I'm running and the 10.5's sat pretty much flush with the rear fender with the spacer, so I might just be leaving that on there. I actually ran into an issue with the front wheels, it seems the wheel hub opening on the 9.5 wheels is physically too small to allow the hub to pass through it. I checked the 10.5 and they were probably an inch or so wider and had no issue clearing the hub (hit the front strut though). Above all else I'm going to need a spacer to clear my brembos up front anyway so it'll be likely be a bit before I can get them on the car :/
codfod
codfod
SoCal
More or less. Looks like the hub bore is quite a bit smaller than I need it to be, never even knew that was a thing before today. Sooooooo barring reboring it, I'm probably going to be selling those fronts and having to order new ones. Chalk it up as another learning experience *rolls eyes*
sleepn_sn95
Indy
You might be able to get some custom spacers made that adapt the sn95 hub bore to the bore on the enkies. Hit up Pete at Fullytorquedracing, he may be able to help
codfod
codfod
SoCal
That's probably a good idea but I'm just going to flip these. I had planned on selling the 10.5's anyway to get the 9.5's square so now I'm just selling all 4 instead of the 2.
B.mad
Preferred Vendor
SoCal
get 10.5 squared. or at least 10s. you can fit it in there.
ReplicaR
You're thinking small. Do a Ford Cosworth CA2010 swap.
codfod
codfod
SoCal
So last week my timing cover started leaking pretty badly so I parked the car and just got around to starting to replace the gasket. Once the timing cover was off, I went to cut the old part of the oil pan gasket that is visible with the cover off as you're supposed to but after taking scissors to it I realized that the gasket has a small layer of metal in between the rubber so it's very hard to cut. You're supposed to cut the visible gasket out all the way to the block but with it being metal it's damn near impossible. I've cut it back as far as I can but it's impossible to get an angle on it at this point. The only idea I have at this point is to take a dremel to it. Anybody have a better idea? Pics for reference
DKblue98GT
A Dremel with a cutoff wheel could work. Obviously you already know how careful you need to be. My concern would be that it will leak oil when you get it back together.
As much of a pain as it would be to replace the oil pan gasket that is what I would do. I recently did it on my car because of a leak. Almost a 1000 miles later things are nice and dry under the car.
codfod
codfod
SoCal
If I can get it flush with the block I'd probably be okay with that. In retrospect I probably shouldn't have cut the gasket at all, but I didn't realize it would be this hard to get through at the time.
If it comes down to having to replace the whole pan gasket, I'll figure out how to make it work with my situation.
Jerry santos
