1994 GT - FTR GT500 BBK
SilverStang
Hey guys,
Having a bear of a time getting my GT500 BBK up and running. Current issue is that neither Russel or MM front SS lines reach my GT500 caliper... I've seen a few threads where people have completed this swap OK, and the parts list just calls for generic SN95 brake lines.... What am I missing??
I believe the MM lines are the ones sold with the FTR kit... So I tried those and no luck, they barely reach even without the wheel turned.
I am running MM non offset lower control arms if that matters.
Thanks
Chris
SilverStang
Update: got them fitted... required that I use the caliper adapter bracket opposite to the instructions from FTR. This mounted the caliper higher up and gave me the slack I needed.
No support from FTR btw, and their rotor spacer was too tight on the hub so it required a bit of time in my oven to open it up as I had no intention of hammering it on. In summary, terrible post sale service and the fit on the spacer should be revised, but the adapter bracket seems high quality.
Will try to remember to update after up and running.
Thanks to Jack at MM for his ongoing support
8mamba24
Hi, When did you buy the FTR Kit?
I need to buy it and have been kind of scared of ordering it, because they don't respond.
Cwacaser
