FivepointSlow
Decided to break all the parts off my 94 off into a separate thread to reduce the clutter in my other FS thread.
87-93 FS thread: http://www.sn95forums.com/showthread.php?62273-87-93-and-94-98-parts
1994-98 OEM Ford Mustang Fog Light Bracket Retaining Bolts
Brand spanking new. I received them in the mail Monday, Realized I was missing other hardware for the foglights and attached them the non OEM way. None of the bolts have been taken out of packaging. 4 bolts total. 2 bolts costs $9.99 from LMR, where I got them, Asking $10.
1994-2000 OEM Ford Mustang Rear Defrost Button
Stock defroster button, minimal wear. No broken tabs or anything. Pulled it off my car to replace it with a billet one. Asking $5.
*Does not include switch itself, this is JUST the button.
1979-95 (5.0) OEM Ford Mustang Spark Plug Wire Looms
No broken tabs. Very good shape. Set of 7. 4x 4 wire looms. 3x 2 wire looms. Just need a good cleaning. Asking $5
1990-2004 OEM Ford Mustang Fuel Shutoff Inertia Switch
This is the switch that sits in the trunk on the drivers side behind the interior panel. It is set off during an accident and cuts power to the fuel pump. Great condition. Fully functional. If you receive it and the button is in the up position, simply push it down to rest it. It can be set off while shipping but this does not affect it. Simply shaking it in your hand will set it off, but when it is properly mounted in the car it needs a severe impact for the body to move enough to set it off. Asking $20
1984-97 OEM Ford Mustang Filler Neck Support
This support bracket is needed to help support the fuel filler neck before it enters the tank. Simply bolts to the pinch weld on the fuel tank and goes around the filler neck. I broke mine off due to rusting when I took my tank out and grabbed this from the junk yard but my fuel tank came with a replacement. So I do not need this. Has minor surface rust around the bottom that bolts to the tank. No serious rusting. You can easily sand it down and put primer on it to keep it from rusting. Asking $5
1994-95 OEM Ford Mustang Passenger Side Mirror Harness
My Passenger side mirror was ruined in the accident but this harness was intact. Works for both driver and passenger side but the wires are color coded to the passenger side. Asking $2
1994-95 OEM Ford Mustang Driver Side Power Mirror w/ Harness
This fits 1996-98 Mustangs as well, but in 1994-95 the mirrors where matte black plastic as appose to the gloss black plastic in 1996-98. Motor works well. Very good condition. Housing has a light amount of over spray that I am sure can be removed with some light sanding or paint remover. Mirror itself has no scratches. And is in OK condition... Asking $10
1994-2004 OEM For Mustang Shifter Knob
Normal amount of wear, pretty good shape. Asking $5
1994-95 OEM Ford Mustang Distributor Cover
Minimal amount of knicks. Very good replacement for a beat up one. Tabs are intact. Asking $5
1994-2004 OEM Ford Mustang Manual Window Handle (BLACK)
Found in the bin of parts I got, no damage to it at all. Asking $5
So if anyone has seen my build thread, you'll know that I bought my car from a local autobody shop that had it sitting for 7 years after it was in an accident. Since buying it I have gotten it to run and pretty much ironed out most exterior flaws, almost all engine flaws, and the interior is pretty much in order except for my drivers seat with the broken bracket...
I have accumulated a decent amount of usable parts from upgrading. And I will update this post accordingly when I pull more things off my car or come across something I missed that I want to sell.
Parts are off my 1994 Mustang GT w/136,780 miles(it's had the same mileage the entire 2+ years I've owned it... hasn't left my driveway), or where in my trunk full of spare parts when I bought the car.
ALL PRICES DO NOT INCLUDE SHIPPING. LOCAL PICKUP IS PREFERRED ON LARGER ITEMS.
I AM OPEN TO TRADES. OFFER ME WHAT YOU HAVE AND TELL ME WHAT YOU WANT.
*ITEMS ARE AS IS, I CAN PROVIDE MORE DETAILED IMAGES IF REQUESTED, NO REFUNDS IF DAMAGED DURING SHIPPING OR YOU'RE 'NOT PLEASED' WITH THE ITEM... I ENCOURAGE YOU TO ASK FOR PICTURES SO YOU KNOW WHAT YOU'RE BUYING.
