1995 GT Auto to 1994 V6 T5 help please.
95gt_stang
Alright, my 95 GT has the AODE and i know someone with a 94 V6 car with the 5 speed. And ive read a few things about it, but what exactly will need to be changed? Or will everything just bolt right up? The guy wants to know exactly what will need to changed and if it will even work before we start swapping. Thanks.
blue9550gt
it should change over pretty easy cause i've put a 2.3 5 speed in a 93 stang wid the 306 in it and just changed the bell
Addermk2
you will need the...
Pedal assembly
clutch cable
transmission (whole)
bellhousing, clutch, fork, cross member
shifter
center console cover
wire harness (the auto harness will need to come out and the manual one put in. It will have the right plugs for the reverse light switch etc.
you will also want to find a T4M0 or J4J1 ECM to put in the car as well.
95gt_stang
Pedal assembly
clutch cable
shifter
so are you saying the bellhousing will bolt up to the 5.0?
95gt_stang
ok, well i really need to know because i will be swapping my AODE to the 3.8 v6 car.
94slogt
yes, the bell housing will bolt up. the only thing you will need to find is and ecu. i left the auto one in my car after i did the 5 speed swap into my 95 and it fell on it face at 4 grand
Dws 95 mustang GT
