1997 cobra t-45
Steven
SC
It'd be easier to just swap the tailshaft housing off a GT on to it. It's all a little different and causes a quick install to be none existent. Is it already manual or an auto?
sn95 bullitt
sn95 bullitt
Elk Grove, California
My car is a manual. I need a tranny and found a trimec t-45 w/ Brass synchros out of a 98 cobra for 300. How hard is it to swap that tail shaft?
clark98gt
Pennsylvania
Just swap the tail housing and your done. Remove the shifter, knock the roll pin out of the shifter base below that, unbolt the tail housing, then re assemble.
philly101
phx az
So yall say n I been roll n around withno speed ometer for a year when all I have to do is change the tail shaft
Musturd
Yea on the newer cars the cross member setup is super gay. But like they said you'll need to use ur back half of the casing because of the cross member. It's really easy once you knock the roll pin out. And unbolt it . Just make sure to silicone the case when you put it back together or shit gets messy.
