275's Up Front?
1996GT
Los Angeles CA
Im running 18" Saleen wheels and was thining about swapping the rears up front. My only concern is that im running a 275-35 tire and dont want any rubbing issues. I am running 1/4" spacers up front though. Should that size tire be ok up front?
wanna_b_03
i have 275's up front with no space and they rub if u turn the wheel full lock. the rims are 17's tho but i dont think that should make a difference!
Passenger
275s up front WILL rub at full lock. Buy some 03-04 Cobra A-arms. You'll gain a little bit more turning radius (Lord knows we need it) and those 275s won't rub at all.
justinschmidt1
my 275s rub up front...but I know my limit...so I dont turn it all the way.....my car is like an 18 wheeler in tight spots though.
Mustanger
Southern Oregon
Keep the wheel at full lock...rev it up & dump the clutch...when the car seems to be pointed the right way ease up & get traction & off you go! You can turn on a dime!
Spd0lit
SoCal
Most likely you will rub the swaybar at full lock. I have been running 275s in front for a little over a year no problem no damage, just a little scuffs on the sway bar. You should have no problem with them. :thumb:
atrainsgt
My 245's rub the sway bar at full lock, I haven't got 275's for that reason. I agree with Justin up there, it turns like a 18 wheeler in tight spots.
Ciotti
It depends quite a lot on the specific tires you go with because some companies run narrow, others wide, others right in the middle. I had 275 Yokohama AVS-ES100's and they rubbed a bit on the sway bar, now I have 275 Toyo Proxes 4's and they don't rub anywhere. My next set of tires will be Falken 615's and I'm %100 sure they will rub the sway bar as they run a bit wide but I could really care less because there's no way in hell I would put anything less than 275 up front.
atrainsgt
I'm about ready for new tires and I decided to get 275's for the front. I might have to add a little thicker wheel spacer though.
jarendt31
Im in the same boat have 275's on 18's and it rubs only when at full lock, so I just avoid that the best I can and noticed a few scuffs on the sway bar, but everything is fine.
realitygt
SoddyRebel said:
i run 255/40/17 on the front and they rub at full lock.
how? lol I have 255/40/17's also and I couldn't rub if i wanted.
245's? that's stock size how the hell can they rub...
atrainsgt
No idea, but they rub the swaybar at full lock. I'm going to loose some more turning ability when I switch to 275's.
realitygt
did you smoke your swaybar or what? what rims do you have?
atrainsgt
They are aftermarket rims but they are almost even with the outside of the fender. A friend of mine has factory 17x9 wheels and 245-45-r17 and they rub the sway bar at full lock also.
