$3000 to spend....
Venom351R
Maine
Paul said:
Without a dyno sheet, I call BS.
Same here. Not on a 302, not goign to happen. yes there are "factory Freaks" out there but nothing that will add on 50 extra HP to the rear wheels
LAFENATU
The tfs kit is carb legal.
EDIT: I am wrong, the kit is NOT carb legal.
MuscleInc1320
so i asked the tech guy at trickflow and he said the intake and heads are carb legal but the cam is not. my only concern is that would my car still pass the smog test with this mild cam. i mean there is no way that they could visually tell i have a cam
MuscleInc1320
so went ahead and bought the trickflow kit for a local shop today. now just gotta wait for it to get here
LAFENATU
You should be fine...the e cam passes smog and the tfs stage 1 profile is really not that much different.
Downshift
Ya I'm sorry but there is no way in hell. He must be inflating those numbers. Maybe he meant flywheel... but most of the trickflow kits hit around 290hp.
My94GT
id buy a used s trim and buy a trick flow top end kit. then get a decent fuel set up....255 in tank, adjustable regulator, and some 42 lb injectors. tune call it a day
White5.0bra
if it was me i'd find a deal on some twedge heads, a cobra intake, and save the rest for a s-strim the stock cam will be fine and you will easily reach your goal with the option to go a lot further.... or just go right for the s-trim. a kb is gonna kick the sh*t out of your trainy and drive train and your gonna have know money. do it right the first time
MuscleInc1320
ok so i am still waiting on my trickflow kit to get here but i am trying to think of anything else i should replace while i have the motor apart. i was going to change the thermostat, hoses, any broken or old vac lines, pcv and i was think of getting a mishimoto radiator from americanmuscle. is there anything else that you guys can think of to replace or and tips you can offer?
MuscleInc1320
well the kit comes with a new timing chain plus the water pump aint that old. do you think the sensors are a good idea though?
Paul
If your car ran fine with the old sensors, no need to replace them. They ain't cheap.
Yellow94gt
The mishimoto is a great radiator and made a vast improvement on my car BUT it won't hold up to ANY abuse... so be ultra careful with it. (I.E. mine cracked at the seal on the tank and is useless and I wasn't pulling that hard on the hose.)
