315s Rubbing!!
Naptown_Stang
Help me please!
Any time I turn left my tire rubs on one of the arms. This is a big issue considering I plan on using the car for road course. I just bought some new sumitomo 315s and dont wanna buy any tires for a while. What can i do??
Throw away the useless quad shocks if you havent already. Also make sure the e-brake bracket is bent away from the wheel, you can normally bend it down some to give extra clearance. If you are still running tails make sure its not hittin on those as well. If you check all that you should be good on clearance
det_riot
Dearborn
check to see if you can visually see it rubbing on the inner fender. If so just take a hammer to the spot it was rubbing. In my case and prob other people too, movement of the rear axle is caused by worn out bushings. Before you hit the road courses/autox check out your upper control arm bushings. Mine were shot and it caused my axle to not sit even in each fenderwell.
Shame302
If its rubbing the quads then you should be able to flip them. Odd that they are rubbing at all though.
Naptown_Stang
Naptown_Stang
Its not hitting the fender but the quad shock will probly work if I flip it around. Although I have no idea when thats gonna happen since I have not garage at college :angry7:
Naptown_Stang
Naptown_Stang
Yeah but I have no tools with me! I have to drive 2 hours home to do anything. If i can find a cheap socket set and a jack Ill do it in the parking lot! I dont care.
I walked into the dorms with drag radials yesterday and they are chillin in my room. No big deal.
2slo95fiveoh
Lawrence, Kansas
most important thing to bring into the dorms is rubbers! :thumbsup:
Venom351R
Maine
If you go through the trouble of un bolting the quads then you might as well leave them off
det_riot
Dearborn
If they're rubbing on the control arms when you're turning, check out your bushings on the actual control arms
Naptown_Stang
Naptown_Stang
:laughing4: ayyee this guy :laughing4:
As far as the quad shocks go thats the only thing rubbing despite my original post. I got down to check it finally. Still looking for a garage/tools to use for 10 min :tongue3:.
Will taking the quad shocks reduce handling?
Win
Kennesaw, Ga
CanaryGT said:
Mine rub and my fenders are rolled...
What is your backspacing though?
I had 315's with a 27mm back spacing on the 03 machined cobra's. I am lowered 2" and still did not rub on the quad i left them alone, i also didn't have to roll my fenders.
Win
Kennesaw, Ga
Venom351R said:
Nittos dont rub b/c they are a not as wide as other 315's
Very true. I do know i measure the width of them on my 10.5's and i wanna say 12.5 or 12.75 "
Naptown_Stang
Naptown_Stang
Im sorry guys i forgot to update my sig. I took off the d/r's for the winter and put on some sumitomo htr-z's 315 rear
CanaryGT
Phoenix
I have 315 Nitto Nt-05's and I rub. I have a 10.5 inch rim. And my fenders are rolled. Im going back to a 285 or 295.
