This is my 4.2 v6 from a 98 f150 with the m112 supercharger. Fun project, just wanted to share under v6 thread.
I have a quick post about the rest of the project: http://sn95forums.com/showthread.php?53944-Orange-1994-Mustang-Project-Pictures
Mostly the uniqueness factory. I didn't really consider the 4.6. It was mostly between this and a 5.0. The v6 has decent gas mileage, less weight and especially with the supercharger can keep up to a v8. I love the look on peoples faces when they hear the supercharger or see whats under the hood. Most people assume its just the 3.8 from the badges on the side.
There was a few guys in the states that had done the project when started, but yeah its a pretty uncommon set up.
or more, depending on your tune.No, I havent yet. I'm going to put a meth kit on it to cool it down and in the spring go get in properly tuned. It should be 300whp.
nice! The tbody actually worked pretty good. Mostly just had to play around with sensors that would fit and work, just like the rest of the project haha. The 3.8 is very similar to the 4.2 but there is a lot of mixing and matching and a little bit of modifying.
If you use windshield washer fluid, you must either find -20degree fluid with nothing added(bug splat cleaner, added scents etc) which is hard to find in some areas. You can use 0 degree fluid or even 32 degree fluid, but you have to add bottles of HEAT to it(100%methyl alcohol) to bring the mixture as close to 50/50 meth/water ratio. The Boost Juice is already 50/50 and is just alot simpler and actually was cheaper for me than mixing it myself.Thanks guys. I hope everything goes good with the meth kit... And thanks for the tip for buying meth, ive heard you can also use window washer fluid and its basically just as good?
How does she sound? exhaust video!!!
