4.6 Rebuild Help
jmstang66
Engine has developed some rod knock again, so I know I'm on borrowed time with it. This happened before and I just went the cheap route and replaced the rod bearings, and it was fine for the last 2 years.
Well now it is back, and I'm thinking this time I should rebuild the whole engine. I don't know too much about engine rebuilds, and have been looking at forged kits from MMR, but I guess my question is whats the best route to go on a cheap budget to get decent power? I have a PI swap, and am going to switch out the cams for some Comp Stage 2s, but regarding the bottom end I don't really know where to go with it.
Thanks for any suggestions or tips guys
Ninety8stang
Duh405
i took mine to one of my local engine shops and used new stock internals, reused the crank and had new rods and pistons put in. I paid $690 for all the work and a new bottom end.
duff daddy
If its not going to be raced, and your not going with a power adder, just go with a basic rebuild and use the stock crank, and get some better pistons. No issue using stock if you want to save some money but the OE crank is defiantly fine
vermilion
maryland
stock crank and forged pistons is what this doctor recommends on stock vehicle. thats just me though.
