4.6 swap.
97SuperSixx
Westville, NJ
Ok guys so im sure some of u have seen my questions about putting the 306 in my 97 and thanks to your input im gonna pass on it. I dont really wanna bother with all the b.s. Along with it. I have a 98 town car that only has 50k miles on it and it runs beautiful. Sold the trans bc im saying 5 speed. How is it swapping my 97 3.8 mustang to a 4.6? Inoe im gonna have to get a t45, and an 8.8 or i found a complete irs setup for 500 bucks. But what can i actually use from the town car? Thanks in advance u guys have helped me a ton so far
Staff member
Lawrenceburg Kentucky
the irs is a good idea, but is a tad wider than a stock -96-98 8.8...not a big deal though. Actually the stock rear will work fine untill money improves. Not sure if you will need the k-member from a 96-98 to fit a modular in your v6 stang or if a simple engine mounts swap is all that's needed.
D3VST8R96GT
Marble Fall, AZ
Good luck .... It's not hard but it's not easy .... Lots of little odds and ends
I wouldn't waste the time on a npi 4.6 .... Even for free hahaha
330CubeGt
Yea a NPI 4.6 isn't an idea motor to swap because of the lack of power :/
03DSGGT
SN95 Supporting Member
Akron, Ohio
My opinion is that if you work at a junk yard, and have access to parts and engines, then I would do a 4V swap. Since your car is a V6 right now, it will be the same amount of work to go from a 3.8 to either a 4.6 2V or 4V.
D3VST8R96GT
Marble Fall, AZ
V6 to v8 swap is a pain.... if u have a full long block/wiring harness its not too big of a deal....
Sent from my SPH-L720 using Tapatalk
I agree!
Your gonna need a lot of donor parts from that junk yard to complete a modular swap.
