40 hp
gslinger
Charleston WV
On the dyno last week only 257 rwhp:(, would like to hit the 300 mark. Any suggestions on 40 hp without tearing down??. 95 cobra, stock intake, 165 heads, crane 2031, bbk x- pipe, long tubes, cold air with 70 tb and bama 4 bank chip.
whiplash473
Northern IL
also gslinger - i'd go over the cam/crank/distrib timing just to double check.....make sure you're still in lin e
RichV
CO
Very suprised you're not making it. I make the same HP without the AFR, 70mm t/b, and tune. I have a GT40 top end, 60mm t/b, shortys, E-cam, and stock GT ECU.
The 257 is corrected?
whiplash473
Northern IL
i was kinda thinking the same thing as RichV.....which has a lot to do with my last post about timing.....hopefully he can get on and fill us in on info soon
Nightmare
Cedarburg Wi
Oh shoot, I was thinking mod motor....Yeah, get a Trickflow upper and lower intake, upgrade the heads, Get better longtubes and go with an H pipe.......
SLOW95GTS
trickflow heads, holley systemax intake, choose whatever cam and ill bet you'll make 300 real easy.
ProKiller
PA
this doesn't sound like a fully functioning motor, not lack of parts. the only thing i'm seeing as the bottle neck is the stock cobra intake. the tune might be off a little. make sure everything is functioning properly, clean the maf, engine is grounded, etc. what was the torque number? post the dyno graph if you can.
gslinger
gslinger
Charleston WV
[/IM]
gslinger
gslinger
Charleston WV
I am thinking I should remove the stock plenum add a trick flow and going to 30 pd injectors, my bbk x pipe has the resonators remove and go back to strait h-pipe. I should hit 300??
Staff online
