5.0 motors
auto_x5.0
I know the 94-95 GT's had 215hp and 285tq from the factory, and the 91 had 225hp IIRC. If this isnt the info you were lookin for my bad bro
TheNatster513
not much electronics are a bit diff lol i was just looking at two the other day.. what a diff in look. basic same block though
LAFENATU
Nothing.
Power numbers changed in 1993 to 215 because ford changed the way they rate HP.
As far as design the fox accessories have brackets vs the SN where everything bolts to the heads. The SN also has a curved throttle body/intake inlet design to fit the engine under the SN hood. The SN also has the EGR bung on the passanger header.
Paul
The '90 5.0 has forged pistons, while the '95 has hypereutectic. Plus all the other differences in timing cover, accessory brackets, intake, and EGR that Rob just mentioned.
94Snake
Valdosta, GA
water pump, main harness (TPS/IAC), distributor. Not the motor but i never knew was the bellhousing is longer meaning you can't use a fox tranny.
TheNatster513
i dont know about the bell housing but i know that the input shafts are different. just a tad shorter in the fox's
94Snake
Valdosta, GA
huh i just assumed the bellhousing would be longer because of the input shaft but the bellhousings i found online say from like 79-95 5.0.
