5.0 swap
351mustang
Hey you guys i took your advice from previous threads i posted and waited till i found a donor car for the swap. i own a 1996 v6 mustang and just bought a totalled off 1995 gt with a 5.0, i was wondering since they are the same body style if i could swap out the rear end and drive shaft when i do the motor swap, also the 5.0 has an automatic trans and i was wondering if my 5 speed standard will bolt up to it and will i have any issue's or problems i may incounter. if you guys could give me some advice or how to from experience it would be greatly appriciated
I want to say the V6 and V8 T5's were identical, but don't hold me to that. I'd def swap to the 8.8" rearend too, but I'm not sure if the automatic and manual driveshafts are the same lengths. If not, now would be a great time to go ahead and get a FRPP aluminum driveshaft. The rearend ought to just bolt right in. Where was the 5.0L wrecked at?
94-427
The 3.8 and 5.0 bell housings and trans are the same as well as mont locations cross member fan and radiator
good look with you swap have a parts car If need any thing
sn95gtvert
Spokane Washington
rear end is straight bolt in, you will need to pull the qaud shock mounts off the gt's sub frame.
i've done a full v6 to v8 swap, just take your time and all will be ok.
351mustang
Thanks for the heads up guys , the damage was done to the front end the driver side fender and front bumper and hood took most of the hit im guessing. and another thing do i have to swap the engine cradle over to my 96 ? and i was thnking also about swapping the heads while i have to motor out any idea's on a good set of heads kinda like a best bang for your buck deal ?
Musttanguy
Lodi, CA.
The K member will have to be changed over to the 94/95 for the 5.0
While the bellhousing will bolt up to the 5.0, it won't work due to the V6's bigger flywheel diameter and you can't use the V6 flywheel as it is 28oz balance and the 5.0 is 50 (bolt holes to bolt to crank are smaller on V6 flywheel.
You will need a 94/95 only V8 bellhousing,flywheel, and clutch as well as manual driveshaft to bolt up to your V6 T5, your V6 T5 will hold up fine behind the 5.0 motor.
Just about everything from the donor car will transfer over.
We have a 97 V6 coupe project car we did back in about 02 that is running an Explorer 5.0 with distributorless ignition (4.6 computer) with everything being changed on the car except the V6 T5, car is making 300 HP and never had a reason to change it out (have a V8 T5 sitting in shop) these transmissions are rated at the same torque as fox body V8 T5's
BII302
Fayettenam, NC
as i stated in another thread earlier, you will need a manual ECU for the 5.0, dont use the auto from your as it will not run correctly, im not sure if there's difference in the v6 manual transmission harness and the manual v8 transmission harness (i wouldn't think so) but if they're different then you'll need a manual v8 transmission harness too
