*steeda tri ax shifter 190 ----> Pro 5.0 or MGW. I take pro 5.0 over MGW. I have MGW
*bbk cold air intake 180 ----> Don't need K&N is fine
*bbk 70mm throttle body 210 ----> Port your throttle body(free mod)
*bbk aluminum underdrive pulley kit 130 ----> You can get it cheaper. Get march or asp kit!
*billet smog pump elim. 65 ----> if it ain't broken no need to spend money on pulley. Leave it
*steeda firewall adjustment kit 100 ----> Why you need this right now?
When i first stated my car. I was on budget too. I home ported everything. If i were you i look at gears. 3:73 or 3:55. I have 4:10's now and it's little too much on the street.
cobra Intake and roller rockers(cobra 1.7),
Get some flow super 44 and have the exhaust shop make the piping. It will be little cheaper then buying $500 exhaust. Get mac headers they are cheap but they are good and out performs most shorties.
MAF stock good for now
Get some new brake calipers. the single piston stocker is nerve wrecking...bullitt or mach1 is cool along with good rotors. get some slotted ones.
It doesn't take ton of money to get the 5.0 going. save money and do not buy the unnecessary stuff for now.
I think you will be able to stay around $500-$600 for these mods if you install everything yourself.
Good luck
