50nx with v1 9pounds
MikeF
i have been thinking of adding a 50 shot of nitrous because i have it and if the air is so hot and that our worst enimy why not shoot a little nitrous because its so cold with a great burn rate.i set my btm on 2 put 1 degree colder plug and heated bottle to 900psi man i should have done this long time ago.with my 4-10 gears shit happens real fast on the tach
mikey94gt
I bet it works great!!! One of the shop cars at the shop I worked at 2 years ago used Nitrous to spool the turbo faster off the line. works great!!!
MikeF
ya i have herd about it on turbo but was just curious and scared.the only thing i have done to short block is put forged pistons and itell you that is a strong little motor ford has grant it im really pushing the limit of fact block.i just keep timing at 9 degree base and let the btm do its thing.when i get a tuner like tweecer will i still need the btm.
mikey94gt
You will not need the BTM, as you can limit the timing per pound of boost with the tuner.
You are pretty safe until about 500RWHP, then you better have a good tune. otherwise, the block splits down the middle. I have seen 600RWHP, but thats just asking for trouble, I think.
