93 GT40p headers on a 94??
JKady
Graham, WA
The ONLY difference between fox and SN headers is the external EGR on the SN95. IF you don't run stock style EGR with the pipe off the header to the intake you can run fox headers. Otherwise you can't. This has been covered over and over since the beginning of time.
ElrodKTPQ_89
Crossett, AR
My apologies for not searching harder first :/
No worries man. I run fox headers on my 94 GT with stock e7 heads. First time around I used the penny trick (stack a couple pennies under the tubing fitting on the bottom of the egr valve) to block the egr. Now with my Cobra intake I just have an egr block plate.
I have exhaust leaks at the flanges. My understanding is the 94/95 collector is not the same size as a fox designed collector. A lot of people seem to run them without issues, but I'll be looking into this when I pull the motor in the next few weeks.
JKady
Graham, WA
That's how I have the header side blocked on my car currently. I haven't scrounged material for a real EGR block plate but if you bolt the valve on upside down it's an ugly but free solution to blocking the intake side.
chatwit
