94/95 Cobra Oil Cooler Question
1Fine99
I'm getting ready to remove the oil cooler from my 95 Cobra for some maintenance. I was curious if anyone knows if there is an o-ring on the "bolt" that secures that cooler assembly to the block?
Her name is Jaz
Mine leaked and I just deleted the whole setup. They only thing you really need is the one hose that comes off of the heater pipe that runs down the side of the intake. That hose goes directly down to the water pump.
I was going to keep the setup but couldn't find the original o ring that goes against the block, it's discontinued by Ford and I couldn't find anything from the aftermarket. It also removed a lot of ugly clutter.
1Fine99
1Fine99
Thanks for the reply. I was actually able to find one of the cooler to block o-rings on eBay. The part drawing I found online makes it look like there is another o-ring on the bolt that secures the cooler to the block. When I took mine apart there was no o-ring there. I got everything back together and so far it has been leak free.
