94-95 tranny swap
Cane88
hey i need 2 know ? all i need to do a tranny swap...do i have2 get a new computer?i have a 94 5.0 auto...want a t-5
jds5.0
If these cars are anything like Fox cars, the auto ecu will work with a manual trans, but a manual ecu will not work with an auto trans. So, I guess you will be fine using your computer, but don't quote me on that!
birel21y
No Computer needed! just get the clutch, flywheel, pilot bearing, t-5 trans, driveline, shifter, clutch cable, pedal assembly and beer. you may need a t-5 trans. harness, but I cant remember.
ProKiller
PA
its better if you do get a manual computer but i'm not sure if it will really affect the engine management when it thinks it wants to shift the auto.
LAFENATU
The PCM will not work correctly. A fox is different because the AOD is not controlled by the PCM.
If you use a auto PCM with a manual the timing will not advance and it will think the car is in park. The PCM is looking for an automatic trans to shift.
jds5.0
Oh yeah! I forgot about the automatics being controlled by the computer in these cars...hence the name AOD-E.
96GTPlanB
